BOV Problems
Discussion in 'Off-Topic' started by Fume, Feb 25, 2008.
  1. Fume
    Fume Member
    well i just put on a HKS SSQ BOV and im sure i plugged the air bypass hose perfect but whenever im driving and let off the gas, the car turns off :confused: help plz?
  2. Sparta
    Haha. Blow off valves FTL!
    Check the flange where it connects to the intercooler. Did you replace the gasket?
    Also did you plug the recirculating hose correctly?
    and also check the intercoolers connection to the throttle body, I noticed with mine that the hoodscoop diffuser pushed down on the bov and slightly moved my intercooler and I had the same problems.
    and when thats all done, try unplugging the battery to reset the ecu.
    and note: your car probably won't achieve the true performance abilities until you get a tune to the bov.
  3. Fume
    Fume Member
    hmm.. i should try the battery thing and yea im planning on getting it tuned as soon as i can get this crap to work :wtc:
  4. siegelracing
    If it's gotten that bad with the BOV there is something else wrong... If there is a mechanical problem it won't be able to be tuned out...
    Siegel
  5. Kokopelli
    Not even with CTRL+i :confused:
    Seriously though you have a leak and a quick pressure test will find it.
  6. Fume
    Fume Member
    there is no problem when i put the stock BOV back on, everythings normal. oh well HKS SSQ for sale :) any takers? lol
  7. RydeBye
    RydeBye Member
    thats wierd how when peeps put a BOV on thier scoobys and have probs...I put on a HKS SSQ on my 06 and it runs perfect if not smoother than before...did you try adjusting it?
  8. Jake
    they have problems because they aren't tuned for them. subarus aren't like hondas. you can't just slap a part on and it expect instant results.
  9. RydeBye
    RydeBye Member
    mine must know i was a honda owner...high expectations :rofl:...i love scoobys so much better than honda...ill never go back
  10. Greg
    Greg Active Member
    Not saying your dumb... But check and see if the gasket is stuck to the stock bov. You have a boost leak somewhere, it dowsn't have anything to with it not being tuned or anything. That would just make it stutter a little between shifts, not shut off.
  11. yerrow
    yerrow Active Member
    no such thing as tuning for a bov
  12. siegelracing
    Correct. If the car was running fine before, it should still mostly run fine with the BOV. You will notice a minor "nastiness" when you lift and/or shift. You need to find the mechanical problem.
    Siegel
