brake bleeding issue ABS?
Discussion in 'Modifications & DIY how-to' started by awdlaunch132, Jul 3, 2007.
  1. awdlaunch132
    awdlaunch132 Member
    Its my first post here! So i am stumped with my brake problem i have. I put on goodyear stainless lines and bled them according to the manual. the pedal was incredibly soft and sketchy to drive. I gave up took it to a shop and had them pressure bleed it. the pedal is better now but still wierd i push the brake pedal once it goes halfway down, the the second time it feels fine. is there still air in my system even after a pressure bleed?
  2. SubiNoobi
    SubiNoobi Supporting Member
    I bled my brakes for the first time recently. I have heard that other cars follow a different bleed order so make sure that you or the shop follows the correct order:
    1. Right Front
    2. Left Rear
    3. Left Front
    4. Right Rear
    And keep the master cylinder topped off, if you let the level get low you might suck air into the system;then you will have to re-bleed to make sure all the air gets out.
    I don't know about this "pressure bleed" from a shop...I used foot pressure and it worked just fine.
  3. awdlaunch132
    awdlaunch132 Member
    I did the right order the second time after i realized subies have a wierd bleeding pattern. I managed to make it a three person job one pushing the pedal one watching the master cylinder and one doing the bleeding so the master cylinder didn't get low.
    Thanks for the response
  4. WJM
    Sweet, super mario kart.
  5. awdlaunch132
    awdlaunch132 Member
    can't deny the mario kart, the greatest racing game ever. I still rock at it
  6. WJM
    I use toad or koopa all the time. I've beat the game several times.
  7. RamblinWRX
    RamblinWRX Member
    DK has highest top speed though, so if you want ze best lap times...
  8. WJM
    Yep. But I'd rather have a good handling kart...;)
  9. SubiNoobi
    wow, amazing how mario kart parallels the real world
    btw I still have that game but have long since lost my super nintendo deck :-(
  10. awdlaunch132
    awdlaunch132 Member
    after reading this post i took out the super nintendo and kicked some ass. btw dk is only good if you can get the boost of the start otherwise you will never catch up. thats why i use koopa.
