brake fluid and pads
Discussion in 'Modifications & DIY how-to' started by jyang, Oct 21, 2007.
  1. jyang
    jyang Member
    so I just bought XP10 and XP8.
    do I have to change my brake fluids too before I swap them in?
  2. scooby_snacks
    scooby_snacks Active Member
    No, I don't think so. Unless you want to add some nice high performing stuff instead.
  3. SubiNoobi
    SubiNoobi Supporting Member
    From what I heard, it can't hurt to get new and/or better brake fluid.
    BTW, nice avatar!
  4. nsvwrx
    nsvwrx Active Member
    haha gotta love tri-gun
  5. scooby_snacks
    what happened to it? I remember watching it on adult swim during my insomniac summer days.
  6. SubiNoobi
    They finished the series after running it at least twice and then moved on. They were showing Cowboy Bebop for a while.
  7. FACE
    You dont have to change the fluid...but you will greatly appreciate changing the fluid and bleeding the system!
  8. miloman
    I don't think your fluid needs to be changed unless (1) it is really old or (2) if you suspect that you have air in your lines.
    Performance fluid will only help if you intend to run your brakes to higher temperatures than the factory fluid can handle. Otherwise, I would go with whatever is cheapest.
    Also make sure to check for compatibility. I run good fluid at all times (ATE Super Blue) and always change it before an event.
  9. FACE
    ATE BLUE/Gold FTW
  10. BKiller
    BKiller Active Member
    So is the blue and gold the same stuff besides the color?
  11. Alex
    Why dont you go ahead and purchase some stainless lines and a higher quality fluid (than stock).
    That way you can change it all out at once.
  12. FACE
    I do believe so...I just used the ATE for the first time and I read/heard they have two colors so you know when you get all the old fluid out.
  13. welery
    welery Member
    You are correct.
  14. SubiNoobi
    Even with fluid of the same type and color, you can see a difference between old and new fluid, like old and new oil. It must make it really easy with two drastically different colors. Do any other brands do that?
  15. Alex
    Id imagine any brand who's fluid isnt black will do that.
    Royal Purple (which is quite purple) actually loses its color as it wears.
