Brake grinding
Discussion in 'Modifications & DIY how-to' started by KingofSiam, Oct 30, 2005.
  1. KingofSiam
    KingofSiam Member
    Hey all. Not sure if this is the right forum, but I'm hearing a strange niose from my right/rear wheel area.
    It only occurs when I braking, so I assume it's the rotors or something. It sounds as if there is some crud on the rotor, because you can hear the grinding with a "frequency": it occurs faster when the wheels are going faster, and slows down with the car.
    Any ideas?
    Also, what are good ways to clean crap off the brake assembly?
  2. miloman
    do u have enough pad left?
  3. KingofSiam
    KingofSiam Member
    I've only had the car for about 5,000 miles. I've never braked hard. So I assume I have enough of everything left.
  4. miloman
    i'd check the pad first and see if its spent
  5. KingofSiam
    KingofSiam Member
