**brake Light**
Discussion in 'Modifications & DIY how-to' started by Nitro, Feb 1, 2007.
  1. Nitro
    Nitro Active Member
    anyone have this problem?
    the light keeps coming on mostly on acceleration then it just goes off .........or when i depress the brake pad it shuts off then:eek3:
    thx for any hits on this........
  2. Intrigue2727
    Intrigue2727 Member
    brake switch
  3. Nitro
    Nitro Active Member
    what about it?:hs:
  4. clemsonscooby
    clemsonscooby Active Member
    There is a switch under the brake pedal. Maybe its under the gas pedal also, like it moved or something. Not completely sure though. Just look behind the brake pedal.
  5. Nitro
    Nitro Active Member
    thanks....i'll go peep under there in a lil bit
  6. gte123v
    gte123v Member
    or maybe your brake fluid is low.
  7. mattprzy
    mattprzy Active Member
    If you are talking about the "BRAKE" light in the dash, then it is the brake fluid being low. If it is your rear brake lights, then I couldn't help you there.
  8. Alex
    Could be like that video on youtube where the dude's friend hooks his horn up to his brake pedal. What brake light are you talking about?
  9. Nitro
    Nitro Active Member
    mattprzy If you are talking about the "BRAKE" light in the dash, then it is the brake fluid being low. If it is your rear brake lights, then I couldn't help you there.
    grrrrrrrrrrrrr thx ya'll...........it was the fluid:keke:
