brake pad suggestions?
Discussion in 'Modifications & DIY how-to' started by AtlxPat, Apr 13, 2010.
  1. AtlxPat
    AtlxPat Active Member
    i think mine may be done and need some new pads, not sure which to go with
    hps/ axxis/ stoptech etc.
    i'd mostly be DDing my car but a few mountain runs here and there.
  2. oneiguy
    oneiguy Active Member
    HP+ in front HPS in the back.
  3. AtlxPat
    wow, never though about that combination
  4. Superdude
    Superdude Active Member
    yeah, really? i've not hear that one either. can you indulge on that a little, pls?
  5. 07Ltd#767
    there's nothing more to think about...they work great for the street and should never fade under spirited driving. If you want to go bigger, you can look at Ferodo or Carbotech pads, but those are going to cost twice as much, if not more.
  6. AtlxPat
    yea not looking to break the bank on pads
  7. oneiguy
    80% of braking is done with the front wheels. So put the stronger pads up front, and lighter pads in back.
  8. oneiguy
    And make sure you buy a bottle of super blue and bleed your lines.
  9. b reel
    forgot a good set of SS lines, maybe adjust the rod on the master cylinder as well, most overlooked mod when coming to brakes.
  10. Matt
    essentially, you could rock stock cheap pads in the rear and Hawk HP+ up front.
  11. Alex
    Know much about Stoptech's new ones?
  12. AtlxPat
    already got a bottle of super blue
    adjusting the rod? first time i've ever heard of this
  13. Superdude
    That's what she said...
  14. Superdude
    i've been auto-xing on stock replacements from autozone. they're not the best pads out there ($35 per axle for the life of the car), but they heat up quicker then a true racing pad. again, for auto-xing. track days are a different monster.
