Brembo slotted
Discussion in 'Modifications & DIY how-to' started by crashtke, Aug 15, 2007.
  1. crashtke
    Just thought I would give some props to brembo. Finally got all 4 rotors on with just regular Autozone duralast ceramic pads and the difference is quite noticeable over factory rotors with similar pads. This thing really brakes now! Soon to add the stainless braided hoses and new fluid for the finishing touch.
  2. lostinthewoods
    Hows the braked ust with those pads ?
  3. bomjoon
    bomjoon Active Member
    wait till you put you some real pads then it will stop like you hit a brick wall.
    ferodos, or even some hawk race pads.
  4. crashtke
    Have not really put too many miles on there just yet, so not too sure about the brake dust. As for the pads I am also looking at the new ones by NAPA called Adaptive one pads. They are some supposedly Nascar inspired pad that is ceramic with some of the properties of semi-metallic.
  5. Alex
    Pics!
  6. keeganxt
    keeganxt Active Member
    may i offer a link unless you've done this already
    link
  7. FACE
    Sweet! Thanks!
  8. crashtke
  9. clemsonscooby
    clemsonscooby Active Member
    I had some ceramics before, EBC greenstuff. They are great for keeping your wheels somewhat clean. Do you know what the upper temp limit is on these pads?
    Let us know how they perform, and have you run any other pad before?
  10. BrianGT
    I bought the Autozone Duralast pads once for the STi, after I destroyed the pads at an autoX event. They are horrible. I bedded them in and could make them fade with 3 stops. They also have worse initial bite than the stock pads.
  11. crashtke
    Were those the ceramics Brian? I just got those because they were cheap and I needed a pad.
  12. clemsonscooby
    I noticed my ebc ceramics didn't have as high of an upper temp limit as the hawks. This was surprising since ceramic is a semi-conductor. I figured it would have been the opposite.
  13. BrianGT
    I just checked, and they were Duralast Gold Ceramic pads.
    Brian
  14. crashtke
    Yup same ones I have, but have not been tracking them, just street driving for now. But I swear the combination has much better initial bite than the factory rotors and whatever pads the previous owner had on there.
