bucking and hesitation
Discussion in 'Modifications & DIY how-to' started by msdogucar, Aug 13, 2009.
  1. msdogucar
    msdogucar New Member
    I've got a 2002 wrx not much modification. I've had it since about Christmas - running smooth till recently. Now I get an intermitent "bucking" (constant pedal, engine pwr low, then it surges, then goes back to low pwr again). I also get a "missing" feeling at higher rpms. Any experience? Any directions to go with this? Thanks
  2. techlord
    coil packs or unmetered air.
  3. b reel
    Vac leak, dirty MAF. Being a Bugeye, would think age and heat cycles has killed a rubber fitting or hose first.
  4. Alex
    Wonder where you got this idea from :eek:
    Check the maf, they have a tendency to go nutty in the summer for no real apparent reason (maybe heat related).
  5. Jake
    yeah heat related (causing misfires, especially in the higher rpms). either your maf is wet (did you recently recharge a K&N filter? too much oil can cause this OR did you recently drive thru a big puddle?) or you have an air leak in the intake AFTER the maf.
