Bucking
Discussion in 'Introduce Yourself' started by tuan, Feb 11, 2006.
  1. tuan
    tuan Member
    i have a new 06 sti with about 400 miles on it. The DCCD is always been in auto ever since i got the car. The car hasn't even been pass 3500 rpm due to break in period but i notice that sometimes mostly when the car is still cold that the car tends to start bucking alittle not a lot, when im tryin to make a sharp turn. It only has happen when im in first gear and making a 90 degree turn or u turn. Anyone have insite on this problem or is it normal in a awd car? Thanks
  2. scuby drew
    scuby drew techos ftws!!EEEE
    my mind is still trying to catch up from a rough night, but i believe that this was talked about in another post not too long ago and it is something about the play in the drive train, but i could be completely wrong
  3. Alex
    Well, how low are the RPMs dropping? Its prob. just low RPM buck, you can always apply more gas to get the rpms back up.
  4. GTscoob
    Yeah, its the fact that we have a front driveshaft and a rear driveshaft and everything has little tolerances. When you load and unload the drivetrain everything 'snaps' into place and you'll get a little buck. It does happen a little bit more in the cold (it seems like you're towing a trailor, aka trailor-hitching). I get it really bad in rush hour traffic where I'll just be barely on the throttle and it's not enough to load everything up so it'll buck front to back occasionally.
  5. tuan
    tuan Member
    So the vote is that its normal?
  6. Alex
    I believe so, yes.
  7. WRXCoupe
    WRXCoupe Active Member
    I buck in my 02 sometimes at a complete stop with my girlfriend in my lap, low tolerance in the drive shaft.....yup. But Seriously I buck especially if I bottom out the steering and am doing a slow turn yup!
  8. Alex
    Nuck...if you buck?
  9. knhtrdr
    knhtrdr Active Member
    ^^:rofl::rofl: funny!
