Then you will need a wiring harness that has the output for those specific headlamps and an input or trigger for the OEMs. Be happy to help!
depends if you want to get fancy and use relays.. I can draw up a diagram for you either way, since I've done it on my own set
Pm me if you need a hand or advise. Alex and Nicad are a great help too. Good luck with it and post up some pics
Well you do have options. Depends how much you would like to spend. Certain companies are able to build you a custom wiring harness specific for your application or you can spend <$30.00 and buy a China-made wiring harness from Matt @ the Retrofit Source. Their harnesses appear to be well built; however, I do not work with them frequently. Just take pictures of them
hook up the positives straight from the battery (with an in line fuse). switch the grounds with a relay, and use the factory harness to drive the coil side of the relay
thanks for all the advise. a guy at work has said that he can help me wire them up. so tomorrow we'll see how it goes. i'll take pics if it all works out.
