Bye Bye #4
Discussion in 'Modifications & DIY how-to' started by Kokopelli, Apr 18, 2006.
  1. Kokopelli
    Well after swapping out piston #2, #4 decided to take a dump. I debated swapping it while I had everything apart but figured since it compression tested good I should leave it alone.
    Looks like I'll be pulling the motor again. Don't know which route I am giong yet. Stock 2.5, built 2.5, forged drop ins on current block or just drop in the other pistons I have.
    If I decide on a new block I am going to run this one into the ground at the track this Friday. Right now even with the low compression the car is way faster than it has ever been. The 20g is a kick-ass turbo.
  2. slowwrx
    I have a full set of STI rods and pistons if you need them, just let me know.
    Matt
  3. Kokopelli
    I have pistons. Its just a matter of do I want to replace stockers with another set of stockers.
  4. Cool_____
    Hmmm now I am hesitating on going the 2.5 swap route. Why are you constantly blowing pistons?
  5. Kokopelli
    Because I push the car very hard. #2 happened after 25k miles of abuse and #4 shortly there after. #4 was my own fault for pushing my car when it wasn't fully tuned. It also didn't help that I threw a bigger turbo on an already injured block.
    The good news is that I am only out about 250 for parts that can't be reused on the next swap so it was worth a try (not 2 though) to fix it cheap.
  6. Cool_____
    okay got ya. So you are saying I should be just fine if I throw on a 'NEW' 2.5 block and take it easy and do directions per SS until I finally get it tuned in. Then crank up the fun!
  7. ck02wrx
    ck02wrx Member
    I would think that forged pistons should be on your list since you run the car so hard. Now you just have to choose which ones to get.
  8. Kokopelli
    Is your car back together yet? When can I come get your old block?
  9. miloman
    sorry to hear about ur troubles mike
  10. Kokopelli
    No worries here. I am getting real good at pulling the motor :p
    This time I am going with a built block with forged pistons coated bearings and a balanced rotating assembly. Hopefully this will last long enough so that I can replenish the transmission fund.
  11. Cool_____
    Hey man thanks for the links....you know what. I actually burned a copy for my buddy to save you the bandwidth ;)
  12. miloman
    do all forged pistons have the bobble issue?
  13. Kokopelli
    No they don't. Its all in the build. The problem is when they just drop in pistons to a new block assuming they'll fit. The block should always be bored to match the pistons. I am going to get my block rebuilt by a professional for 1400.
    Coolrex,
    Glad you got the manuals. When are you starting on your project?
  14. Cool_____
    Eh when I get the funds or when my motor goes which won't be for a while I hope. I like to do ALL my homework and research before starting something. I have always done this and came into working on the car like I have done it 100 times. Saves me a lot of headaches, time, and frustration. Sometimes I wish others would do the same instead of fubaring something up and then whine and complain about how crappy their car is. I would like to do it around Fall of next year. I am getting married next April so I'll be strapped for cash until after then. Now if the motor or tranny goes before then that's a different story but it's still running strong.
  15. miloman
    thats the best way to do it :)
  16. Cool_____
    Yep better to ask questions and pick others minds for a while instead of totally screwing something up and having to do it all over again.
  17. Kokopelli
    Are you mocking me? :squint:
  18. Cool_____
    It sounds like that doesnt' it....I totally didn't mean it. You drove on that motor for 2 yrs right? LOL
  19. Kokopelli
    Just messing with ya.
    BTW. Forget about that six speed in Bama. It's all mine. ;)
  20. Cool_____
    Sweet. You getting the entire package for 4 grand or you work something sweeter with him?
    I wanna stay with the 5 speed so I may go RA gears....hope it'll hold the torque.
  21. Kokopelli
    I am getting the whole package. I am picking it up tommorow.
    Dance party anyone?
    :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
  22. wrxin8or
    ooooooooooooo
  23. Cool_____
    So Liquid what headgaskets do you use when using bone stock WRX heads? I am gonna stick stock WRX valvetrain and all as I just can't get that much $$$. All I want is 400/400 all day every day. Some say STi headgasket some say 2.5RS HG some say Cometic. Which ones?
    Anyone know? There's too much bs on Nasioc.
  24. slowwrx
    Axis Racing has the cometic headgasket you need in stock. I cant remember the thickness, but I know he keeps them.
