Brainstorming!!! I have a fender mounted cai. I was thinking of putting the oem air duct intake back on (after modifying it a bit to fit around the aftermarket maf tube) to cover the big opening and possibly force "cooler" air, instead of the current heat going in from the engine bay. Will it make a big difference? EDIT: Here's a crappy BB pic I took after modifying and installing it
You will probably benefit more from cutting the duct to blow outside air directly onto the MAF itself. If it heat soaks the ECU will adjust.
Yeah as long as the air flow from the snorkel isn't pushing into the filter in the direction of the intake itself! Remember the ram air issue that we never could figure out until WJM looked at the car? :rofl:
One the dyno you will see no difference.. what you should do is monitor you air intake temps before and after the mods and see if they change.
Ok. Had my AP monitor it for a week (with and w/o the ram air duct) seems to be a ~10 degree difference with it installed. Not sure if it's a significant number but hey it's a little cooler and it was free.
I still have stock air box on mine. Had CAI before, but i bought a stock airbox on here. Didn't feel any loss from deleting the CAI. And I don't have to worry about CAI sucking water into my motor again.
It should be okay if you had the splash guard on, shouldn't? My CAI is fine, although my car is at stock height with the splash guard. I've driven through some really heavy rain, but I've never hydrolocked.
