Hi Everyone. Question: Will the following combination work? Engine/heads/ecu/sensors- 02 EJ205 Cam Sprocket- 08 WRX Cam Shaft- 04 STI (with plugged avcs) Ive been piecing together some swap stuff and I need some help getting this right. I know the 04 camshafts will work in the 02 heads, but Im unsure as to whether or not the 08 wrx cam gears will work with the 02 wrx electronics and what not. Any advice or input? Thanks
No you need to use the ej205 cam gears, they have the pickups for the cam signal built into them. Matt
