Camber Bolts Help!!!
Discussion in 'Modifications & DIY how-to' started by AWD_Tiger, Jun 23, 2006.
  1. AWD_Tiger
    AWD_Tiger Member
    Hey guys i am installing my ingalls camber bolts on my 02 wrx sedan. I want to make sure i am installing them correctly. The factory bolts (head) is pointed toward the rear of the car and the nut is facing forward. when i put my aftermarket bolts in facing the same way i can hardly get any adjustment out of them due to the bolt hole(oblong) running horisontaly. but if i put the aftermarket bolt in facing the other way(head of bolt towards the front of the car) i seem to get more negative camber, but i am new to this so i am not sure.... if any of you are running camber bolts (or have knowledge of how they work) could chime in it would be greatly appreciated:sx:
    BTW.. i have an alignment appointment at noon tomorow.
    Thanks in advice :)
  2. Alex
    I mean, if you get more neg. what's the big whoop? The nuts, to me, seem to be on the side they're on for ease of installation. Dont quote me though :D
  3. Cool_____
    It shouldn't matter what side you put them on?
  4. AWD_Tiger
    AWD_Tiger Member
    Thanks for the help guys.. it turned out to be fine.
