Hello all, So, if I keep my scholarships for next semester, I will be picking up a boatload of parts, particularly RCE lowering camber plates. I have stock struts with JDM Pink springs, and I know with the stock diameter springs, they will hit the inner fender well after not much negative camber. I was thinking, if I turn the camber plates and use them as caster plates, like WJM did, I might be able to squeeze out a little bit more camber, while gaining some positive caster. I know positive caster has little effect on Subarus until 7 or 8 degrees (not sure with other suspension designs), but having some can't really hurt can it? Anyways, just looking for theories or suggestions. Thanks!
I have heard that 6 degrees of caster is good, idk what your stock numbers are, but some STi's come with close to that stock. Maybe that's the newer ones, idk.
