Camber plate torque specs?
Discussion in 'Modifications & DIY how-to' started by clemsonscooby, Oct 27, 2006.
  1. clemsonscooby
    clemsonscooby Active Member
    Dec 13, 2005
    1,536
    0
    Does anyone know what the torque specs are for the camber plate bolts? I am not referring to the strut mount, but the actual bolts that adjust the camber. They normally look like little hex bolts. Thanks for any help. Specific numbers or ranges are better than "hand tight", "1/4 past hand tight", etc...
  2. bluetwo
    bluetwo Active Member
    Feb 21, 2006
    1,512
    0
    I guess nobody knows man. Just to give it a shot in the dark I'd say 90 ft. lbs. but I honestly can't even call that an educated guess. I don't think heat is a factor really so it's probably just a matter of vibration resistance.
    Maybe some of the mechanics will see this.
