Camber
Discussion in 'Modifications & DIY how-to' started by wrxbacano, May 1, 2007.
  1. wrxbacano
    wrxbacano Member
    hello guys ive been out for a while now but im back wit a new garage hehe, well just a quick question does the wrx have any way of adjusting the camber on the back stock? cause I know im a lil off on the right back wheel and when I went to change my brakes today I saw a couple bolts that looked like thats what they did, so please let me know thanks for any help
  2. WJM
    No adjustment in stock form.
  3. yerrow
    yerrow Active Member
    ingalls bolts
  4. clemsonscooby
    clemsonscooby Active Member
    There are a couple different kinds of camber bolts. I used SPC in the rear and Ingalls up front. Both will work anywhere. I know GTScoob had a few pairs of Ingalls still left for like $20 or something. Thats a pretty good deal, since you would normally pay over $30 for new ones. You can't use the OE front camber bolts in the rear though, so don't try. The front bolts are too large of a diameter to fit in the rear strut.
  5. wrxbacano
    wrxbacano Member
    thanks for the input I guess Ima have to get them soon, are they hard adjust after you get them in?
  6. clemsonscooby
    Once you get them in, you take your car to get aligned and then you don't move them at all. They are really easy to get in. You need to remove your wheel and then remove the top strut to brake knuckle bolt with a 19mm socket. It's going to be on there tight since the torque specs for that bolt are 130 ft./lbs. Don't loosen the lower bolt, because this will hold your alignment in place until you get to a shop to have your alignment done. I would rotate the bolt until you can feel it touch the metal and it stops spinning. Throw the nut on and tighten it down with a good amount of force.
    If you are racing, I would suggest alignment specs of -.7 to -1.0 if not, than -1.0 to -1.3 (OE) and toe should be 0 on both sides. Once its aligned don't adjust it at all, because adjusting camber will change your toe which could drastically wear you tires.
  7. GTscoob
    I've still got 2 sets of the Ingalls bolts FS, $15 if you want a pair.
  8. clemsonscooby
    ^^^Thats an awesome deal and you are supporting another member.
