Camshaft Position Sensor
Discussion in 'Modifications & DIY how-to' started by soobaroo227, Aug 21, 2005.
  1. soobaroo227
    soobaroo227 Member
    I'm throwing a Camshaft Position Sensor CEL code right now. My car drives fine, but I'm throwing that code. I looked up prices of the sensors, so they're not that bad so I could just order a new one. Only problem is I don't know where the sensor goes and if there is just one or two or possibly four. I guess I need to take my car by a dealership so they can check it out and find out where it is. Does anyone know where these sensors are located and if I could just check them myself to see which one is fouled or just not positioned correctly or something?
  2. Alex
  3. jonnyboy0150
    jonnyboy0150 Member
    Its never guaranteed that a new sensor will fix it tho, it could be a wiring problem. Be sure you check it out pretty thoroughly before buying a new sensor.
  4. slowwrx
    You can change it yourself, if you need help let me know and I can walk you through it on the phone should only take 10 minutes, if your near Marietta I actually have a spare one.
    Matt
  5. slowwrx
    Oh its located on the drivers side of the car on the back of the timing belt cover near the top sprocket.
    Matt
  6. soobaroo227
    soobaroo227 Member
    Could I maybe meet up with you and check out your spare sensor. How much would you want for it? By the way, I live in Downtown Atlanta, so I could meet you somewhere in between or in Marietta, I don't really care. I'm not from Atlanta though, so keep it simple so I won't get lost. :bigthumb:
  7. slowwrx
    Ill drop you a PM with my phone number
  8. Goose013
    Goose013 Member
    you don't by chance have a lightened fly wheel or crank pulley do you?
  9. Goose013
    Goose013 Member
    nevermind this thread is old...lol. Hope you figured out what it was
