Can 05-07 STI suspension be modified to fit 04 STI?
Discussion in 'Modifications & DIY how-to' started by WRboXer, Jul 22, 2011.
  1. WRboXer
    WRboXer Active Member
    I think i remember just needing to drill a hole to make it fit? Is there an easy way to make 5x114 fit 5x100 lowers?
  2. Doug@DBW Motorsports
    Only difference is the front struts. On 04sti the front uprights are narrower. So I guess you could make a spacer shim and it would work fine.
  3. WRboXer
    Was pretty sure the physical bolt pattern on the front lowers were different Doug.
