Can I bed my brake pads again?
Discussion in 'Modifications & DIY how-to' started by jyang, Oct 24, 2007.
  1. jyang
    jyang Member
    So I was in the process of bedding my new carbotechs and it started pouring today. I m not sure if the bedding process worked or not. Can I just go and do the bedding process again?
  2. FACE
    Pouring? Like a leak? And have you already tried to bed the pads in?
    I would make sure you do not have a leak and then bleed the system again. Make sure when you have someone pump the pedal that they do not let the pedal up at all befor you tighten the bleeder screw and check that the resivor is full, then bed the pads in once the pedal is stiff.
    Good Luck Bro!
  3. WJM
    pouring RAIN.
    As long as they got a decent 1st heat cycle on them, they are fine.
  4. kartboy
    kartboy Member
    ya it was pouring brake fluid from the sky!!!
