can p0136 cel code for o2 sensor effect my performance?
Discussion in 'Introduce Yourself' started by Easy11s, Oct 2, 2009.
  1. Easy11s
    Easy11s New Member
    ive been getting this code for about 3 weeks now...been thinkin bout going with the spark plug non foulers trick but i dont have to pass emissions so i dont know if its worth the trouble right now...it didnt throw any other codes but it has before like misfiring on a couple cylinders...Any advice would help...thanks
  2. RSConvert
    Did you do any mods recently before the cel? If nothing probably just a bad sensor.
  3. Easy11s
    Easy11s New Member
    oh yessir!...the usual...vf34,fmic,4 inch downpipe with 4 inch cat delete to hks high power,cobb accessport,565 injectors and so on...but that was all done bout 10k miles ago and never had a cel code till bout 3 weeks ago
  4. RSConvert
    Probably a bad sensor, no?
  5. Mike@TTR
    Mike@TTR Active Member
    Couple possibilities, but yes probably a bad o2 sensor or frayed wiring.
