Can't get gar into programming mode to program a key fob
Discussion in 'Modifications & DIY how-to' started by MattACK, Feb 24, 2013.
  1. MattACK
    MattACK Member
    I used these instructions from NASIOC as I've been pouring over many threads on how to do it, but I cannot get the car to even enter programming mode. It is on my 2004 wrx w/ a turbo timer (which is turned off) and nothing else to speak of.
    I bought a used remote off of ebay which is identical to my stock one and the LED illuminates when I push the buttons.
    The car is not in valet mode.
  2. b reel
    install new battery in the remote
  3. MattACK
    MattACK Member
    I'll give it a shot, but I cannot even get the car to honk or chirp as it is supposed to when it is in programming mode.
  4. orndog
    orndog Member
    I thought I read somewhere you had to hit the lock or unlock button 6 times.
  5. MattACK
    MattACK Member
    Only reason for that, from what I've read extensively, is for the tear-drop style remotes that require you to enter the code for the controller via the lock/unlock button.
  6. Took me about 25 times to get mine to work.And as far as I can tell I did it the same exact way every time.Just keep trying..
