Car at SOG Getting Alignment RIGHT NOW!!!!
Discussion in 'General Community' started by BelvnAWD, Sep 16, 2005.
  1. BelvnAWD
    Okay, others may not be that excited about it, but I am. It will be the first time I really get to see how the Konis do. I may also end up with eccentric camber bolts if they can't get a decent performance alignment with the stock hardware. It'll cost more, but its should be a one time cost and make a big difference in the way the car handles. Also got a rental Legacy Wagon. Even though its not the GT, it is still verrry nice. Wish I could talk my wife into a wagon!
  2. SnarkBreeder
    SnarkBreeder Member
    I've been meaning to get an alignment, how much does it cost?
  3. BelvnAWD
    Wellllll, there is the rub. I wanted the performance alignment and talked to Scott after I had already paid for the regular alignment ($89.95) I may end up with the Camber bolts which would cost $60 for parts and $95 for labor so it could balloon to somewhere close to $300. I assume I would then also be charged for the performance alignment, which I am sure is more than the regular alignment....
  4. miloman
    performance alignment is $150 at SOG
  5. monk
    speaking of handling, milo do you have the EDFC yet?
  6. miloman
    nope... someone showed me how to get to all the damper controls without actually taking the back seats off and without any tools... takes me 2 min to set the dampers... just cant do it while moving but i dont think i need the EDFC so much so justify $300+
  7. monk
    if you wouldn't mind showing me sometime that'd be cool. i still think i'm getting the EDFC but but that will be a christmas gift from the wife.
  8. Alex
    Good luck with the alignment.
  9. SkullWRX
    SkullWRX Member
    Well I'm excited to know how they handle! :wiggle: These will most likely be my next purchase after the TBE... assuming they're worth the $$.
  10. miloman
    monk: remind me next time we meet up n i'llshow u
    belvn: good luck with the alignment... let us know how it feels...
  11. siegelracing
    Not to worry buddy. You got right near 1.6 degrees all the way around for the $89.99. I stretch where I can to get the $149 performance alignment numbers for the stardard cost of $89.99.
    The performance alignments often take 2+ hours, which makes the $149 a deal ;)
  12. BelvnAWD
    Yep, thanks Scott! I almost called back and told you to put the Camber Bolts on no matter what, but I am glad I didn't! Looked for you to say thanks, but you were gone to lunch. I only got to take one hard turn on the way back to work, but it tracked much better than before! The konis/STi springs and a more agressive alignment really transform the car. Can't wait for the Subbie Challenge to really push it!
  13. siegelracing
    Glad you like it. Enjoy.
  14. SnarkBreeder
    SnarkBreeder Member
    The 1.5 all around is pretty much all the wrx can get stock anyway, right? What's the stock alignment supposed to be at?
  15. rolling_trip
    rolling_trip Active Member
    as soon as i get a rear sway, sign me up for one
  16. ck02wrx
    ck02wrx Member
    Can you explain the process?
  17. Alex
    My basic understanding of the process is that the alignment machines use a laser based system. Each wheel gets a gyroscope of sorts that has one of the sensors in it. There is a central machine that reads the sensor inputs. Hope this is making some sense...The car is up in the air, and you're underneath it adjusting the camber/caster of your wheels. The more you push the camber, the more the wheel tilts in and the sensor picks up on this and reads a degree from the axis. That should make a bit of sense I hope.
    I dontknow if you're looking for more like, "what is an aligment" or what though...
  18. ck02wrx
    ck02wrx Member
    Sorry, I forgot to put a Quote in my post. I was asking for someone to explain the process of adjusting the rear dampers with out removing the seat.
  19. miloman
    u have to take ur seat off one time to set it up
    1) take off the bottom of the seat
    2) remove all the bolts at the bottom of the back rest (don't remove the back rest)
    3) put the bottom of the seat back in and bolt it down
    now the seat will feel just as sturdy as before when u sit in it... now
    1) go to one extreme side of the backrest
    2) hold it at the top and bottom
    3) pull it up and then towards u
    this way u can get one side unlocked... pull the top of that side towards u and theres enough room to fit ur hand thru to get to the dampers and adjust them... when ur done, simply pull the end up and then away from you and it will lock into place
    hope this explanation is clear... if not, let me know if u see me at a meet and i'll show u
  20. ck02wrx
    ck02wrx Member
    Thanks.
  21. siegelracing
    Thank you Alex for your explanation, ;) I was trying to decide how much ck02 really wanted to know about the process of aligning, then I figured that wasn't what he had meant to ask because he spent like 3 hours with me corner balancing and aligning a couple of weeks ago... ;)
    ck02, every time I see that 12.3 at 111 I'm impressed. How's that Hydra treating you?
  22. ck02wrx
    ck02wrx Member
    I have had the Hydra for over 1 year and have been very happy with it. I need to tune it for all the changes I've mad and take it back to the track. I'm also very happy with the alignment and corner weight adjustments you made on my car. Now the car is more fun to around around corners but I need some better brakes, which should arrive on the 22nd.
