Car overheating? **HELP**
Discussion in 'Modifications & DIY how-to' started by josh booth, Jun 1, 2010.
  1. josh booth
    josh booth Active Member
    As the tile says my car started too over heat this morning on my way to work. I have a GMS aluminum Radiator and the GMS 160 thermostat also the GMS silicone hoses. Any ideas?
    Thanks in advance,
    sounds like the thermostat is sticking.
  3. nicad
    theres either no coolant, the thermostat isn't opening, or the waterpump no worky spinny
    the cooling system is about as simple as it gets
  4. josh booth
    ^^ Matt I was thinking the same thing. Butt I just putt the thermostat in about a year ago.
  5. josh booth
    I checked the coolant it's full.
  6. Matt
    doesn't mean it can't fail. My OEM thermostat failed after about 2 years.
  7. josh booth
    Souds good I guess I will start with thermostat first. Thanks guy's.
  8. Matt
    how many miles are on the car? has the water pump ever been replaced?
  9. josh booth
    100,000K Not that I know of....
  10. Matt
    okay.
    typically the water pump gets replaced with the timing belt...at 100k
  11. b reel
    Would think about new timing belt, pulleys, and pump all at the same time. Josh at Import Image or Fred Bean have a good price on package deals.
  12. Cool_____
    I know you put in the thermostat a year ago but are you sure you installed it right? They have this hole that has to be facing up (I believe that's right so double check).
  13. Matt
    :squint:
    you'd think it would go bad....immediately, not after a year of daily driving
  14. Cool_____
    Not necessarily. I'm not talking about the direction of the spring.
  15. josh booth
    SOG putt it in so I hope they putt it in right..... :rofl: Butt I guess you never know. Butt I am with Matt I would think it would go bad quick....
  16. Cool_____
    You need to pressurize the cooling system to see if the system is working correctly.
    How is it over heating? Is it while you are driving? Or while at a standstill?
  17. josh booth
    Like I said it just it over heated this morning for the first time. Butt it was moving.... I went too lunch and drove around for about an hour and no overheating. So I am not sure.
  18. Cool_____
    Sounds like an air bubble. Just drive the car and keep an eye on the coolant gauge. If it creeps up, kill the engine ASAP.
  19. integroid
    Also make sure the fans are working. I had that problem with my car where one of the fans was not working.
  20. josh booth
    Eddie the fans are working....
  21. Mike@TTR
    Mike@TTR Active Member
    Any bubbles in the coolant or odd smell to it?
  22. Trey
    Trey Active Member
    If you do replace the thermostat, get one that fails open....trust me, worth it!! ;)
    I think the one I used was a Grimmspeed one, can't remember.
  23. josh booth
    Not till I left the cap off an ran the car for about 5min. Then there were some bubbles butt no odd smell.
  24. Mike@TTR
    What about when you first start it up?
  25. mattprzy
    mattprzy Active Member
    About a year ago at 120,000ish miles my car started over heating. Had to buy a new radiator. Have not replaced the water pump and the thermostat was last changed at like 80k-ish miles. And I'm fine now at 140k miles.
  26. josh booth
    No sir.... And the car has not overheated again. So I am not sure what was going on.
