caster/camber
Discussion in 'Modifications & DIY how-to' started by thebigph, Oct 11, 2006.
  1. thebigph
    thebigph longing for another subie Supporting Member
    i just put tien flex on my wrx and i was wondering if all i need to do is get the car aligned or if i need a new caster camber kit to make the degrees of the tires lay flat on the pavement? any advice
  2. Alex
    I might be mistaken, however, I dont think teins pillowball mounts can adjust caster. Just camber.
  3. thebigph
    that's ok i think camber is my biggest issue right now i just had to replace the tires on the front of my car b/c they were wearing away on the inside...
  4. calmnothing
    You need an aligntment.
  5. miloman
    correct... they are not designed to adjust castor
  6. clemsonscooby
    clemsonscooby Active Member
    Castor is really only important if you are professional drifter and you need lots of turn in. The camber and toe will be the only things you need aligned. Eventually, you may want to have your car corner weighted in order to adjust ride height on each wheel. If your corner weight is off drastically on one tire, it may cause excessive wear to that tire. I would just stick with the camber and toe for now and just monitor the tires. I don't know if there is a thread about good alignments for different applications, but I am sure we can figure it out depending on what you will be using them for.
