.:.:.Cat-Bak.:.:.
Discussion in 'Modifications & DIY how-to' started by WrxCrazy, Dec 28, 2005.
  1. WrxCrazy
    WrxCrazy Active Member
    I'm getting a EVO II cat bak.. greddy...
    do i need a down pipe with that??
    and whateles i can change with the cat bak??
    to incresse camel power... and get a cool sound.. loud and deep. :wiggle:
  2. rolling_trip
    rolling_trip Active Member
    is the catback 3" or 2-1/2"? If it is 3", you may get a little rattle, becauce of the wrong offset from the stock downpipe. and of course after doing your turboback, you may want to look into engine management, like ecutek of cobb, to unlock the power you just made.
  3. Weapon
    well if i understand you correctly the greddy should bolt up to the stock DP but it would be more beneficial if you had a downpipe to unlock any substantial gains as well as a deeper exhaust note. if you do change the downpipe you may as well do the uppipe at the same time since you will have everything taken apart anyway
  4. scuby drew
    scuby drew techos ftws!!EEEE
    im sellin my hks 3 in downpipe if you are interested
  5. WrxCrazy
    depends how much :cool:
    yeah depends? :rolleyes:
  6. Alex
    Man, you are crazy with those emoticons...
    It should bolt directly to your stock dp, but be aware that's a serious bottle neck.
  7. WrxCrazy
    what do u mean by bottle neck? sorry kinda slow on that term.. ?
  8. oucatch21
    oucatch21 Member
    bottle neck means its like a beer bottle... you are going from a big pipe to a much smaller pipe which is not good for airflow....
    good for beer bad for air
  9. WrxCrazy
    hmmm oh okie.. i understand now..
    i was thinking abt going perrin down pipe and up pipe.. will that fit in with my greddy evo II CatBak?
  10. jonnyboy0150
    jonnyboy0150 Member
    Yes it will.
  11. WrxCrazy
