CEL, much sadness
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Jul 11, 2006.
  1. Mad Mallard
    Mad Mallard the mad mallard
    Driving home around 11pm CEL came on...@ 59,300 miles
    going to autozone in the morn or something to get em pulled...
    nm, just a p0546
  2. suby113
    suby113 Member
    you Need a tune now!
  3. P0546 Exhaust gas temperature sensor circuit high input
    Did you put your uppipe in? you could have bent the egt probe in the process.
  4. Mad Mallard
    the up's been in for around 2000 miles...
  5. suby113
    suby113 Member
    My 04 did this removing the second cat in the upipe causes this code to come about. the only way around it is to get tuned and have it shut off. If it was a p0420 that is much easier to deal with just see what Scott posted on the (boost creep or what )thread.
  6. 1ll-WRX
    I got this or a very similar CEL one time on a long trip with an agressive gas additive.....I also had an aftermarket up-pipe as well....random tech....and I cleared it and it never came back again?....:wiggle:
  7. Sometimes it can be a rich mixture or a lean mixture or just a flook mine did it a few time but it was a wiring problem...lol...i say clear it out and go for a ride and see if it comes back. oh yea mine also did it on Realllllly cold mornings if i got on the interstate and got up to speed a little quicker then usual onramp driving it would kick on.
  8. Mad Mallard
    it will clear itself out if the sensor gives an ok signal long enough. I forget how many miles have to go by, but its part of the OBDII spec..
    even if it doesnt go away, its not hurting the engine operation, is it?
  9. mckenzietj
    mckenzietj Member
    If you have a catless up-pipe you just need to unplug the egt sensor and put in a 2.2k ohm resistor and the code will never return. The egt is only used to measure the precatalyst temp so if there IS no cat the sensor is useless anyway! Mine's been this way for about 2 years, no problems.
  10. Mad Mallard
    i'm no mechanic or engineer. Does this Sensor actually affect how the engine runs at all?
    and will it hurt anything if left as is?
    <----no money...
  11. Goose013
    Goose013 Member
    no it doesn't do crap. just buy the resistor and plug it into the wiring harness under your solenoid cover.
    you can get a set of 5 resistors for about $1
  12. wrxguy
    wrxguy Member
    yeah you can get it at radio shack that what i did for mine
  13. goixiz
    goixiz Active Member
    IF there is no 2.2k resistor on the plug Will the AP still take care of the CEL ?
  14. wrxguy
    wrxguy Member
    i think so depending on the maps that come with the AP. Unless you get it pro tuned and they will shut it off!
  15. Mad Mallard
    it went away!
  16. 1ll-WRX
    only stage 2 and above ;)
  17. mckenzietj
    mckenzietj Member
    The only crap it does do is read pre-cat temp in case of over heating, generally caused by misfire, whch would put the ECU in fail-safe or limp-in mode.So basically, without the pre-cat it "doesn't do crap, just buy the resistor..."
  18. Kokopelli
    Unless you reset the ecu, the light went off but the code is still stored. If you are getting emission tested anytime soon you will still fail.
    I'd reset the ecu and see if it comes back after that.
  19. Mad Mallard
    heh, emmissions on an 04 wont be due for another...year in my county
