Changed my air filter...wow!
Discussion in 'Modifications & DIY how-to' started by ShaneSTI, Jul 2, 2007.
  1. ShaneSTI
    ShaneSTI Active Member
    So I checked my stocker air filter, and it was dirty as hell. I went to Advance Auto and picked up a K&N filter since they were having that 25% off sale. All I can say now is, wow! I didn't realize what a difference in power, spool up response can change dramatically from changing it. And yes I do know what an air filter does.;) One question though...with ecutek am I okay with the drop K&N filter since the car has more air coming in? I was told by SS that If i went cold air that I'd have to retune it. But what about the drop k&n?
  2. FACE
    Yeah man I got a k&n and was really surprised with the difference...I would not think it would effect your tune but im not sure
  3. ShaneSTI
    bumpin for question.
  4. Matt
    It shouldn't affect your tune at all....
  5. WJM
    Drop in filters do not need a retune. For other intakes...I'd recommend a tune.
  6. ShaneSTI
    thanks guys!^
  7. JPM Coachworks
    JPM Coachworks Registered Vendor<br/>Its delux son, delux. Supporting Member
    Is this the filter that requires lubrication?
  8. monk
    yeah, it's a spray you buy. you re-oil it after you hose it down and let it dry
  9. FACE
    there is a cleaner kit by k&n
    you tap the dust off the filter, soak it with the spray cleaner, rinse and let dry (natural dry) and then there is an oil you spray on it
  10. ShaneSTI
    yeah...it comes w/ the lubrication on it. after time, when you clean it, the you get the spray stuff after its cleaned.
  11. nsvwrx
    nsvwrx Active Member
    be careful not to over oil it.. the oil can fly off and mess with your maf.
  12. ShaneSTI
    ^good point! it comes oiled, but not enough to mess with the maf initially. just when you clean it, don't overkill it w/ the cleaner that k&n sells.
  13. MarkM2016GTI
    K&N FTW...I always use their products....both air and oil filters....Scotty B told me about them a while back.
    Mark
  14. dubs04wrx
    dubs04wrx Member
    i need to get that filter
  15. knhtrdr
    knhtrdr Active Member
    The Green works pretty good too. Glad ya like the k&n man.
  16. BrianGT
    I swapped to a k&n filter over a year ago, and about a couple of weeks ago, I realized that I hadn't cleaned it at all since I installed it :) I hosed it off with a high pressure hose, then blew the rest of the crap off with my air compressor, and lubed it up with k&n filter oil. Man, the car pulls much better now, and I didn't realize what the car was missing :) It just wasn't pulling as hard up top before.
    To those who swap or install aftermarket air filters that are re-usable, please remember to clean them :)
    Brian
  17. ShaneSTI
    nice brian. how often would you suggest cleaning it? i'm thinking every two oil changes???
  18. BrianGT
    I think it is supposed to be cleaned every 3 months.
  19. XanRules
    XanRules Active Member
    I've gotta check this stuff out.
