anyone done this that feels like imparting wisdom? ive never changed diff fluid on any car... so any insight would be much appreciated. also what fluid do you recommend for the diff? for the trans as well? anything i can buy locally? i want to do it this weekend so i dont have time to order anything offline. thanks m
The only fluid to use in a Subaru transmission is Subaru Extra-S. For your rear diff it depends on what car you have. If you have an STI, you need the Subaru LSD specific gear oil. If you have a WRX, you can use Extra-S for that as well. We are currently stocking Extra-S, and you can check out the thread here:http://www.wrxatlanta.com/forums/showthread.php?t=23878
it is a bitch to get the diff fluid in from the bottle. They sell pumps but you might be able to do it if you are careful. Just have some kitty litter on hand, (ask me how I know)
I have actually been looking for the pumps, anyone have one or know where to get them? how much do they cost?
McMaster Carr. http://www.mcmaster.com/#oil-pumps/=1deyhe Scroll down to suction pump. That is the cheapest I know of...
Maybe i got a cheap one, but I bought a suction gun from Advance Auto Parts, and it wont hold a seal. Tried it even with just water, thinking the oil was to thick, with no luck. Ill order one of those, see how it works.
Loosen the top bolt first before the bottom one. If you can't get the top open then no point going further because the bottom will obviously drain your fluid. What do you have? WRX or STi? If STi Subaru Extra S or Motul Gear 300 in the tranny. Subaru LSD rear diff fluid ONLY and NOTHING else. If WRX Subaru Extra S or the famous Uncle Scotty's cocktail (search that on Nasioc). Any good 75/90 fluid including the Extra S for the rear diff of the WRX.
lol I used an empty bottle of Lucas fluid to "pump" the LSD fluid into the rear diff. It was a bitch and required some Spartan strength but the diff got full and the bottle looked more like a ball when I as done with it.
http://www.ronshomeandhardware.com/...56&Click=1014&cvsfa=1873&cvsfe=2&cvsfp=189456 I'm going to try this pump. If it doesn't work meh, cheap enough. The manufacturer seems pretty decent as far as what they produce: http://www.plews-edelmann.com/
both bolts are pretty tricky since it is hard to get leverage if the car is on jackstands or ramps. How much can you bench press? My method was to lay under the diff with a breaker bar in the plugs and push up REALY HARD. It takes some force.
