check engine code
Discussion in 'Modifications & DIY how-to' started by sleeper31204, Aug 31, 2007.
  1. sleeper31204
    sleeper31204 Member
    i got my car (02 wrx) tuned today by S.S. up at Batlground, love the way he does what he does. i drove it home, 100 miles south to macon, and had a check engine light come on. code "P0420", i can clear it with accessport v2. but I would like to know what it means if possible.
    Nothing seams wrong with the car, so I'm not sure if there is something wrong or not.
    p.s.~S.S. I'm noticeing boost gaps in throtle with second and third, what could this mean?
    Gaps~goes up and down really fast through gears, the boost that is.
    thanks
    -William...
    IIRC, that's the catalyst efficiency below threshold code.
    sounds like you're running catless and the O2 sensor is freaking out....
  3. Matt
  4. sleeper31204
    sleeper31204 Member
    sweet thanks a big one.
    now to the other tho, boost surge goes high and low through rpms ?? lost
    just got it tuned to, what could this be saying, reset or reflash ecu i think???
    thanks
    -William...
  5. moose
    The P0420 should have been disabled with the tune.
    edit: can you be a little more specific with the 'boost surge' stuff? Are you seeing boost fluctuate up/down?
  6. sleeper31204
    sleeper31204 Member
    yeah, but not seeing, feeling it through throtle responce. its there, and im not sure why.
    im just gonna call S.S monday.
    thanks
    -William...
  7. nsvwrx
    nsvwrx Active Member
    ss usually disables that code... call him up
  8. techlord
    Don't wait till Monday I know SS he wants you to let him know of anything of concern. Better yet text him he loves that...unlike myself.
  9. GTscoob
    Thats just the downpipe cat sensor CEL, you can get spark plug defoulers and space the 02 sensor a little farther out of the exhaust pipe and it will go away easily. That or call Siegel and have him change the tune to remove the CEL and email you the new map for your car.
    As far as boost fluctuations, are you running a stock size boost restrictor? Elaborate more on what happens with the boost rising and falling.
  10. sleeper31204
    sleeper31204 Member
    ok, tomorrow i will get out and run the car. little late here now and all.
    but as far as the restricter plug, S.S. replaced it with another, saying it was better for my tune, something with the boost timing. didnt question him on it ether. the thing thats sucks is that he is so far away from me, and it didnt feel like this up there, but not to worried about it right now. going to see how it runs tomorrow during the day, after i clear this code i got. he made two maps for me, one regular and one with low waste gate.
    let me give yall some numbers tomorrow tho, and that way i can say a little more.
    thanks for the help and the code link, came in handy.
    -William...
  11. sleeper31204
    sleeper31204 Member
    but hey, the car came out nice. i went in with somewhere in the line of 190 whp and 180 w lb ft. ran out with 240+ hp and 255+ lb ft. stock wrx with up and down with cold air intake. boost is at 19 psi. S.S. did say with a higher reading dyno, i could see higher numbers, hint the + at the end of those numbers there.
    -William...
  12. siegelracing
    I can e-mail you a map with the P0420 disabled. That's usually turned off on the base map that I start with... Is the boost only going up and down at part throttle, or even at full? Either way I can e-mail you a map.
    In the future, please feel free to contact me (M-F 8-8) with any issues.
    Siegel
  13. siegelracing
    I have another map for you. E-mail me and I'll reply with the new map.
    Your car might require less low-throttle wastegate duty because I think we tightened the wastegate arm a bit further than stock...
    (this car come in a BASKET case of mechanical boost-control issues)
    Siegel
  14. sleeper31204
    sleeper31204 Member
    yeah, no doubt about that. sorry again, but thanks for all the help.
    as far as the new map, does it have less low throttle response? with the boost i mean?
    -William...
    p.s. i took the arm down 1/2 turn and right after i pulled out from a friends house, it did that pop again. but has not done it since this morning.
  15. sleeper31204
    sleeper31204 Member
    hey Scott, what was the name of that software again, i forget! lol!!
    ill look around for something tonight.
    -William...
