check engine light...
Discussion in 'Modifications & DIY how-to' started by mokinbird87, Jun 11, 2007.
  1. mokinbird87
    mokinbird87 Active Member
    my car is throwing a check engine, so i hooked up my AP, and it says code P0031? any idea what this is? on the cobb website, they say that it can show up from a low octane gas, and possibly the engine is misfiring. i guess it would be a good idea not to push it right now.
  3. mokinbird87
    P0031- front O2 sensor heater control circuit low??? wth is this?
  4. mokinbird87
    so how would you fix it?
  5. Kokopelli
    new o2 sensor
  6. mokinbird87
    damn, any idea how much it is? also, is it safe to drive my car hard at this point?
  7. lostinthewoods
  8. lostinthewoods
    I would check the wires from your O2 sensor to make sure they didnt get melted or anything.
  9. 1ll-WRX
    I had this before and had to get the sensor replaced...
  10. mokinbird87
    any idea what causes this? is the O2 sensor simply old? or is it because i`m catless?
  11. cannarella
    cannarella Member
    If it is the front one it would have nothting to do with you being catless. Maybe just old.
  12. 1ll-WRX
    I'm guessing it can go whenever for no apparent reason...pretty sure that's what they told me
  13. Matt
    sensors fail all the time. you know you get a discount at SoG off parts, right?
    I'm not sure which sensor you would need, either WRX or STi, since you have a swap done...
  14. pEd
    you're car has close to 100K on it right??
  15. mokinbird87
    yes sir... and now the leak from where the DP and the midpipe meets is REALLY bad... i dunno if that is the one that is causing the sound, but my car sounds like a helicopter... but it's kind of weird because it will only sounds like that when i`m traveling at over 40+ mph.. it wont do it when i`m just standing still and reving it.. maybe it is something else, and if it is, i`m going to be pissed
    i hate the fact that my car is soo old.. it cost more to maintain than to mod...and it doesnt help when you have NO money..
