clutch fluids
Discussion in 'Modifications & DIY how-to' started by knhtrdr, Feb 27, 2006.
  1. knhtrdr
    knhtrdr Active Member
    I haven't had time to tinker on my car like I want to yet workin 2 jobs. but how hard/easy is it to change the clutch fluid??
  2. sol drums
    sol drums Active Member
    tranny fluid is not hard at all. i would say it's about the same as changing your oil.
    it's a bit more of a PIA if you have a large top mount.
  3. knhtrdr
    Thanks gonna get some good stuff in before I take to the track and da mtns. :ddirty:
  4. sol drums
    have you thought about putting in the tranny cocktail???
    1qt. Redline Lt.Weight Shockproof
    1qt. GM Synchromesh
    1qt. Redline 75w90 High Performance
    you can get em at Mustangs Unlimited
  5. Alex
    Its 3.7qts for a complete flush isnt it ?
  6. sol drums
    for the 5-speed?
    mine took a little over 3qts.... i bought 2qts of Redline 75w90
    ...you maybe right
  7. knhtrdr
    yep, that's what I was going for!!
  8. Alex
    I think I rember seeing this in the shop manual for the 5 speed.
  9. sol drums
    i'll check my fluid level when i get home.
  10. Cool_____
    I thought the cocktails was
    1qt. GM Synchromesh
    Fill the rest with Castrol Hypoy C 75/90
    Can't find the Castrol for the life of me. Will the other Redline work just as well?
  11. calmnothing
    You can order the Hypoy from midwayautosupply
  12. Cool_____
    Any way I can order this to be shipped to me? I am in SC.
  13. brettedmonds
    brettedmonds Member
    i know auto zone has the hypoy c and synchromesh b/c that is where i bought mine. castrol is in a white bottle and synchromesh in yellow
  14. Cool_____
    Not here they don't. MidwayAutosupply has the Castrol and Summit has the Redline. Ordered myself and my buddy what we needed. Then got Synchromesh from AutoZone and Mobil1 75/90 for the rear end.
  15. BlueRex
    BlueRex Member
    I just did mine , used the redline 75w/90ns. Shifts smoother. But i have to be going slower for it to go into first without grinding then before i changed it. Any ideas ? I'm don't know what was in it before. I put the 75W/90 in the rear diff. I noticed alot of sludge on the rear diff drain plug, what would cause that age, contaminated ?
  16. BlueRex
    BlueRex Member
    Amazing ! I drained some of the trans oil, mixed in some syncromesh and its shifts perfectly. No more crunch 3>4, no issue with 2>1. Wonder if there will be any long term effects of having some of the wrong oil in the trans. Cant be much worse then all the gear grinding and crunching.
