Clutch slipping!
Discussion in 'Modifications & DIY how-to' started by D_K, Sep 2, 2008.
  1. D_K
    D_K Member
    My clutch is slipping, and it happens when I give it a little bit of gas.. in low rpm it works fine but once i give it some gas it starts to slip (typically at higher rpms). Soon after it produces that awful smell when you ride your clutch.
    I don't know a lot about the drive train, so i am not sure what to buy. Do i need to only replace the clutch or is it part of a package deal.. where i need to buy other things that go with it? I was actually looking at this:
    http://www.hopupracing.com/actstdihedup2.html
    inputs are greatly appreciated
  2. Jake
    you just need an OEM replacement or aftermarket equivalent replacement clutch. thay can be picked up just about any where. i bought mine off of ebay i think. had topspeed install simply because i didnt have the tools or the time to do it. its a fairly labor intensive install process.
  3. Tray@topspeed
    Tray@topspeed Member
    I would go with the basic Act street disc. It is good until you change to a 6 speed.
