i cant reflash to stage 2. i am completely catless (sti uppipe and helix 3" catless DP), but i dunno why it wont reflash to stage 2; do i need to connect the green connectors or is that not neccessary to reflash on version 1? what were the steps to reflash again?
well , do it now it isn't that hard. find the white loopback plug and plug it in below the steering wheel and there should be two green plugs. hook those two up together. then when you put you key to "on" position, you shoul dhear the fans turning on and off. Now plug in the AP and should be able to flash it
