cobb exhaust
Discussion in 'Modifications & DIY how-to' started by para83, May 27, 2008.
  1. para83
    para83 Member
    will the SPT heat shield still fit with the cobb downpipe and is it worth wrapping the cobb downpipe
  2. theish05
    theish05 New Member
    i just wrapped my down pipe today. 50 feet for 40 bucks at summit. it will help a lot, its worth it from what ive heard. If you do it grab the high temp silicone coating, to spray over it to keep the water out of it.
    ps dont wear anything white while doing this.
  3. Batlground
    Batlground Active Member
    There's a local place that does ceramic coating and is very reasonable. Ceramic does a better job of heat retention than the wrap.
    Matt
  4. Berzerklo
    Berzerklo Active Member
    And where would this local place be hmmm?
    Pricing?
  5. socrates42
    socrates42 Member
    how many feet did you need for the wrap?
  6. theish05
    theish05 New Member
    i did the up pipe and down pipe with 50 feet, with about a quarter of it left over for other projects :)
