Does anyone know where the Cobb software is? As in an electronic form of the software cd that would come with the AP... I have checked on Cobbtuning.com, but I am just not finding it.
Not that new, its AP1. The problem now is that the cable I bought for it, a 9-pin to USB isn't recognizing the device. So I can't load any new maps onto the AP.
I believe that the version 1's only work for a 9 pin to 9 pin serial connection. At least that's what mine came with.
Yeah, I think the software is not compatible with a usb connection, unless someone can tell me otherwise. I will see if anyone is nice enough to bring their laptop and cable so I can load a stage2 93octane map to the dyno day this Saturday.
I used a usb to serial connector when I had my original AP1. You'll most likely need to install a windows drivers for that connector, I did.
I installed the driver from radioshack since that is where I bought the cable from, but it is still not working. Its saying that its not in sync with the device when I try to connect to the AP.
