Cobb Stage 1
Discussion in 'Modifications & DIY how-to' started by Matto357, Oct 13, 2006.
  1. Matto357
    Just installed, have to say there isn't a very noticeable difference in overall power, but it comes on quicker and it is much smoother.
    I also LOVE how they adjusted the throttle by wire system so that it isn't as much like an on/off switch.
    Idle seems a bit smoother too.
  2. 1ll-WRX
    yeah sounds about right...the Cobb OTS maps are gonna be more conservative, that's why peeps get protuned or street tuner
  3. goixiz
    goixiz Active Member
    give it a day and a few miles
    The IAM is not at 16 yet. You will be smilling soon
  4. IAM not aware of what iam means.conservative good ragged edge bad..
  5. 1ll-WRX
  6. moose
    If it's an '06 it'll never go to 16. :)
  7. Matto357
    Ok, so what does having it at 16 do? Just advances the timing a bit? What's the timing start at?
  8. Deke
    Deke Active Member
    I thought the same thing when I installed mine, it isn't like a dramatic feeling power increase, but it does smooth everything out a lot. I did definitely notice it though when I unmarried the system from my car one time and drove around. Not only was it not as smooth, but there was a noticeable power difference in high rpms.
  9. knhtrdr
    knhtrdr Active Member
    Do you have the new one or the discontued one?
  10. Matto357
    discontinued one, honestly I may just return it and get a new one when they come out IF the new one provides big enough differences, if not I'll keep what I got.
  11. knhtrdr
    I'm gonna be needing some kind of engine mgmnt. soon cause I think I shot fire last night when I over reved by mistake:eek: and backfired didnt cut off or anything though but you should have seen the cars move away from me or stop downtown.
  12. Deke
    Deke Active Member
    I don't believe the new one is going to be any better as far as it's tuning capabilities are concerned, more just creature comforts.
  13. Turbonater
    Turbonater Member
    The new version just injects a little more turbo juice into the ECU's InterThrillerChillerZone Activator.
  14. FTZ
  15. miloman
  16. Matto357
    Welp, not sure what happened but I think the IAM has moved, the drive home tonight I definately noticed better pull in the 2k to 3k range. Well worth it and highly recommended.
