Cobb
Discussion in 'Modifications & DIY how-to' started by caasi, Jun 6, 2009.
  1. caasi
    caasi Member
    If my battery dies, do i have to download the map again? I have the access port 1.0..
  2. goixiz
    goixiz Active Member
    depends
    you will loose real time map only
  3. caasi
    caasi Member
    what does that mean?
  4. nicad
    it means you'll lose the real time map. you won't lose the flashed map
  5. wrxin8or
    Yep, just reflash the realtime map and you are good to go!
  6. SonicBoom
    SonicBoom Active Member
    If your realtime map and base map are the same, no action required... Correct?
  7. Mike@TTR
    Mike@TTR Active Member
    Correct. Any learning the ECU has done will most likely be lost, so drive it nice for a day or two...depends on how spot on the map was.
