Compression results are in :(
Discussion in 'Modifications & DIY how-to' started by Kokopelli, May 30, 2009.
  1. Kokopelli
    Crompression results are in adn it doesn't look good.
    in 1,3,2,4 order
    180, 180, does it even matter, 70
  2. pEd
    wow...sucks to hear that it is what you thought. :(
    PM when you're working on it and I'll come by and lend a hand
  3. nicad
    why 2? odd
  4. Kokopelli
    it was 4. I figured why bother testing 2 when 4 was at 70.
    Compression testing a hot motor = pain.
  5. wrxin8or
    Oh damn that sucks. Let us know when its going under the knife...ill bring the firefly
  6. Kokopelli
    I'll probably pull the engine tommorow if I can find a beater.
    There is a Justy on Craigslist that I was thinking of getting even before this happened.
  7. nicad
    ah ok. figured you would have just started on cylinder 4 ;)
  8. Alex
    Ouch! :eek:hnoes:
  9. Mike@TTR
    Mike@TTR Active Member
    Man mike, that sucks. Sorry to hear...any thoughts as to what caused it or what it might be? Are you thinking head gasket, rings, piston, what?
  10. ScoobyMike
    ScoobyMike OG Mod
    doesn't look good bro......im thinking rings maybe!!
  11. integroid
    Wow Mike, that sucks and sorry to hear. What kind of pistons/rods do you have in your motor?
  12. Kokopelli
    I had 60k miles on the motor so it was only a matter of time. Forged pistons don't last forever.
  13. oneiguy
    oneiguy Active Member
    sorry to hear that. let me know if you need anything
  14. FACE
    Yeah sorry to hear this man...maybe I'm glad I didn't stay longer :(
  15. kingwrex
    kingwrex Supporting Member
    fail bro. well, just build it better and stronger this time
  16. Jake
    oh well can only get better from here
  17. Bug-Rex
    Bug-Rex Active Member
    + 1 ^^^
    It was still freakin awesome to see your car on the dyno though.
  18. slowwrx
    60K is pretty good mileage out of a built motor, if I remember correctly you had CP pistons in that motor. I would be pretty happy with that you can't expect much more.
  19. wagunz_pwn
    like I said, I can be there for help while I have all this free time...just say the word.
  20. XanRules
    XanRules Active Member
    I'm just down the street and I need something to occupy myself with.
  21. dontcallitarex
    dontcallitarex Active Member
    This sucks. :(
    Boosted H6 time!
  22. Kokopelli
    Mahle 4032's with stock rods.
  23. pEd
    I didn't realize you had 60K miles on those pistons.
    That's a good life out of those Mahle's.
  24. Kokopelli
    I have 120k miles and I put them in at 70 so its actually only 50k but that is still not bad. They lasted the same as my original 2.0 where as the stock 2.5 block only lasted 20k
  25. Sparta
    what did you run on the 2.5 block? Im at about 30k on my hybrid, should I be worried?
  26. 07Ltd#767
    he make's POWA
  27. Kokopelli
    I think running a nitro / meth mix was the death of my stock 2.5 ;)
  28. Sparta
    o ok lol
  29. Sparta
    And actually my car's making more than yours right now, until you get tuned, and more than 80% of the cars that Dyno'd yesterday :fawk:
  30. Cool_____
    Mike you said you think nitro/meth killed the car. When you say nitro/meth do you mean nitromethanol or you mean meth in conjunction with Nitrous?
    Also Mahle's going back in or some CP's?
  31. Kokopelli
    I ran a mix of nirto and methanol with my meth injection. I got up to a 50 50 mix before things went bad.
    Here is a comparison I did on back to back runs with the only difference being 100% meth on one and an 85% meth 15% nitro mix on the other.
    http://mk.dataoceans.net/public/images/Nitro/nitro.xls
    When I was up to a 50/50 mix I was adding quite a bit of fuel to keep from going lean. But alas apparently it was not enough and the stock pistons gave up the ghosts.
  32. Cool_____
  33. Kokopelli
    I think the maf was a little past its max voltage ;). And it was even scaled for a perrin big maf.
  34. nicad
    what was the the A/F when the MAF maxed out? were you datalogging?
  35. slowwrx
    Time for an AEM
  36. crippies42
    crippies42 Member
    Sorry to hear about your car Mike, I know how you feel. If you need any help let me know.
  37. Cool_____
    Matt what does not having an AEM have to do with this?
  38. kingwrex
    if its the blue justy in marrietta thats my old one
    tougemiata
  39. integroid
    My guess would be the AEM has better maf scaling capabilities, duh. :)
  40. Cool_____
    Well duh but Mike was talking about things that happened years ago....not recently ;)
  41. Kokopelli
    what kind of shape was it in when you last drove it?
  42. Kokopelli
    I'm tearing down the block tonight to see what has gone wrong. Hopefully the walls won't be too damaged.
    I'll post pics when I get it apart.
  43. kingwrex
    it was in pretty good shape. Body was pretty straight on it, it was lowered on 175/50/13 sumitumo htr 200 and had a new exhaust on it, but it had cracked at the downpipe. I drove it from roswell to ptree ind daily. But shortly after i sold it he tried to be mr mechanic and did something to it, called me telling me it wouldnt run. He tried to adjust the carb. But i do know he bought another spare justy so im assuming it runs now. I thought about buying it back myself.
    http://subarujusty.proboards.com/index.cgi?board=memberjustys&action=display&thread=1283
    tougemiata
  44. Cool_____
    Well Mike how did the pistons themselves look? I saw where you said the cylinders looked fine.
    Pics or ban!
  45. Kokopelli
    No obvious damage to 2 or 4 but usually you don't loose the crown so you can't tell til you pull the piston.
    I didn't get the heads off of 1 and 3 yet because I stripped the exhaust cam gear bolt.
    If anybody close to Roswell has a corded drill and a big bit I can borrow send me a pm.
  46. Cool_____
    Those bolts are such a pain!
  47. Cool_____
    Also maybe the pistons didn't crack or die and the rings simply gave out.
  48. Kokopelli
    Pistons are out and the ring land on #4 is toast. It also broke the ring as well which is something I have not seen before.
    All the cylinder walls look fine but I am going to have a machine shop check it out and see if it needs to be bored over.
    Now that I know the block is ok I have some decisions to make.
  49. slowwrx
    Actual broken rings are pretty rare and if I recall correctly its usually because tolerances are to tight.
  50. nicad
    bore to 100mm, and drop some more pistons in. can be sure of the tolerances that way
