Compression test cost.
Discussion in 'Modifications & DIY how-to' started by baddriver, Aug 5, 2007.
  1. baddriver
    baddriver Active Member
    Does anyone have any idea how much should a compression test should cost at either a Subaru dealer or an in dependent shop on a four cylinder boxer motor?
    I'm thinking of getting this done on an out-of-state car I'm interested in.
  2. WJM
    At SOG for SOHC engines, its $98.50.
  3. baddriver
    Excellent,
    I am going to call the out of state Subaru dealer and the Seller, and try to coordinate a compression test for sometime this week. It seems like relatively cheap insurance when looking at a used car.
  4. pEd
    you may want to consider a leakdown test as well.
  5. WJM
    but only if the compression is lower than stated in the FSM. A leakdown at that point will tell you if the rings are giving up, or if a valve is leaky.
  6. baddriver
    Thanks,
    May I ask about how much a leakdown test is and how involved it is? ( again for a SOHC turbo flat-4)
  7. WJM
    leak down is an additional $197.
