Compressor housing nipple line to bcs fell off??
Discussion in 'Modifications & DIY how-to' started by gfred024, Jul 15, 2012.
  1. gfred024
    gfred024 Member
    Jul 29, 2007
    281
    0
    I have been noticing a high pitched not normal whistle when getting into boost in 5th & 6th gear. Also over boosted and threw a cel, happened a few months back but i thought it was because of the cool weather. I checked the hoses last night only due to the noises ive been hearing i havent overboosted lately, I found the hose from the housing nipple to the bcs was off which could have been off for months im not sure. I put it back on and zip tied it. Now I'm not hitting target boost. Anywhere from 5-10 psi low. Boost leak?
  2. h23bb2
    h23bb2 Member
    Feb 26, 2012
    167
    0
    its possible. What method of boost control are you using? Stock ebcs? 3 port? MBC?
  3. gfred024
    gfred024 Member
    Jul 29, 2007
    281
    0
    Prodrive 3-port
  4. h23bb2
    h23bb2 Member
    Feb 26, 2012
    167
    0
    its been awhile since I seen one of those... lol
    When you overboosted its possible you blew off another line or unsettled a coupler.
    You have an AP and or wideband? Its really easy to determine a leak with some form of datalogging and/or wideband.
  5. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    0
    Check IAM?
  6. h23bb2
    h23bb2 Member
    Feb 26, 2012
    167
    0
    i'd be more interested in A/F correction/learned values and MAF voltage at WOT than IAM/DAM. If there's a WB on board, running really rich in boost would be a sign of a boost leak...
  7. goixiz
    Oct 23, 2005
    1,482
    0
    Cel=IAMdrops ( depends on how much) = BOOST & timing retard
    Lview can easily give you the indications
  8. h23bb2
    h23bb2 Member
    Feb 26, 2012
    167
    0
    Sure, but it depends on how the tuner set it up. I've seen som ROMs where the IAM would have to be below 2 (on a 16bit ecu) for wgdc to be reduced.
    I've also seen some maps where KCA was set to 1/2* in some regions or even across the board. If the IAM dropped to 8 and the KCA table was set to 2*, it may sound horrible, but in actuality the ecu only pulled 1*....
    Like you said, LV will tell all since it also shows AF learned values...
  9. gfred024
    gfred024 Member
    Jul 29, 2007
    281
    0
    Thanks for all the replies. I took everything apart then hooked it all back up. Reflashed and now it's running perfect.
