Coolant mix
Discussion in 'Modifications & DIY how-to' started by cannarella, Apr 20, 2009.
  1. cannarella
    cannarella Member
    What is the proper collent to water mix for the 2.0 turbo? Car is getting near 60K and need to change the coolant.
  2. integroid
    50/50 Subaru Coolant only.
  3. FACE
    Agreed ^^^
    Make sure you get the additive as well its like 4 dollars
  4. goixiz
    goixiz Active Member
    additive not needed for 05 EJ20
  5. FACE
    I have understood that the coolant additive was to stop/help find small leaks in the system. And why not put water in an aluminum radiator? I would not think twice about it :)
  6. FACE
    ninja time warp ;)
  7. XanRules
    XanRules Active Member
    while we're on the subject, apparently you're not supposed to put ANY water in an aluminum radiator? o_O
  8. goixiz
    pls justify
  9. integroid
    Err...since when? Even the factory service manual tells you to put 50/50 with Distilled Water.
  10. XanRules
    I dunno. I read it somewhere. lol
  11. blindfold
    blindfold Active Member
    so what did they suggest to fill the radiator with?
  12. pEd
    peepee!! :rofl:
  13. Davidwrx
    Davidwrx Member
    buy the subaru premix.
  14. So in all seriousness, has anyone changed out there coolant with anything other than subaru stuff? And what did you use? Why only subaru coolant? its just coolant.
  15. integroid
    Its not just coolant:) If you look at your coolant, it is much darker than Prestone or any other off the shelf coolant. Something about special additives or something. Talk to WJM about it. WHy risk it for a measily $10.
  16. pEd
    Here's a link to WJM's thread about coolant.
    Click Here
  17. UpSideDownDesi
    UpSideDownDesi Active Member
    I forgot how much of each i added but it was prestone coolant, distilled water, and Water Wetter.
  18. nicad
    I have and didn't think twice about it. there is a GIGANTIC thread on nasioc about this
    edit: http://forums.nasioc.com/forums/showthread.php?t=504002
    they talk about some of the additives of various coolants and which are safe to use. Unabomber is kind of a dipshit sometimes (he's a sonar technician what can I say) but there's a lot of good information in there.
    edit2: actually I've met him he's not that bad of a guy. except I bought a monitor from him that died 8 months later :unamused:
  19. cannarella
    cannarella Member
    Thanks. I think I can tackle this now. I have been putting it off for so long. I will just premix 50/50 (with a little pee :naughty:) and then add it. I did buy the Subaru coolant from SOG.
    Any other advice to make sure I get all the fluid out when I drain it??? I will have all the time in the world to do it so I don't mind letting it come out the little drain hole. Need to replace thermostat? One other question, where do you dispose the old stuff?
    Sorry I haven't been around much, working 4 10 hour days is nice but the day off I just veg out and do nothing. I still need to do some other maintenance so you will be hearing from me again.
  20. nicad
    best way if you can manage it is just yank off the lower radiator hose and let er rip. the drain petcock is a piece of shit.
    you can try a local auto parts place to collect it, but most won't. try calling your local city/county gov't and see if they have somewhere to dispose of it. or if you don't really give a shit just pour it down the drain
  21. Cool_____
    Collect it in oil drain pan. Dispose of it at a recycling center.
  22. cannarella
    cannarella Member
    That's what I figured. Just need to find the place...
  23. You could probably just take it somewhere like a valvoline or a jiffylube. They take old oil, I wouldnt see why they wouldn't let you get rid of some coolant.
  24. integroid
    I buried mine in the back yard:)
    I would change the thermostat while you have the coolant drained. It will take you an additional 10 minutes.
  25. blindfold
    change to a cooler themostat?
  26. goixiz
    i wont recommend it but i know of a few usage for the coolant
    not good if you have pets around the house or kids
    the used coolant has heavy metals in it so i would also be careful when working with it
  27. integroid
    Yup, I would on my car just because it is heavily modified...
  28. blindfold
    the only one i've found so far are rated at 160F, not sure if these will overcool plus an upgraded radiator
    anyone know what is the coolant temp range for OEM with no FMIC blocking the radiator? Looked everywhere and havent found the info yet
  29. cannarella
    cannarella Member
    I'm stage 2 so just the OEM one? Do I need to get if from a Subaru dealer or can I go to any autoparts store and get the thermostat and gasket?
  30. integroid
    Can you really overcool an engine? I wouldn't think twice about getting the 160 degree thermostat and putting it on a stcok car in the SOUTH.
    I would get one from the Subaru dealer or an aftermarket one like the gimmick motorsports.
  31. cannarella
    cannarella Member
    Would that affect my tune?
  32. integroid
    I wont do anything to your tune. I know Josh at Import image has the Gimmick Motorsports ones in stock and have it up here in two days.
  33. cannarella
    cannarella Member
    Ok last question, is there any place locally that carries them in stock?
  34. cannarella
    cannarella Member
    Just got off the phone with Josh and one is on the way. I may pickup one of his raditors while I am down there in 2 weeks to fix my stock leaking one.
