Coolant question - Where is it going?
Discussion in 'Modifications & DIY how-to' started by lostinthewoods, Jul 22, 2010.
  1. lostinthewoods
    I am noticing it seems every time I top off my coolant tank that it is down below L just after a little driving. I am not see any visible leaks or smell coolant burning. Where the heck is it going? There has to be some pin hole leak some where. I had noticed a while back some coolant marks on the underside of the hood.
    Whats the best way to trouble shoot my mysterious leak?
    thx:eek3:
  2. Kokopelli
    pressure tester
  3. Alex
    Cardboard under the car to see if it leaks overnight?
  4. lostinthewoods
    No leaky over night. have tried that.
    So where do i need to get a pressure test done or is this something I can do?
    The funny thing is I don t have any issues with the car running hot. Its like the coolant tank is just over filled.
  5. Davidwrx
    Davidwrx Member
    I will lose a bit every now and then. I think our coolant likes to f**k with us to make us think it may be leaking out the head gasket / exhaust. I choose to just keep an eye on it an not worry about it!
  6. integroid
    Wirelessly posted
    Same problem I had and it was a small leak at the block and upper radiator hose.
  7. lostinthewoods
    I may not worry then. Car never over heats even in the texas 100+ degree heat.
  8. Matt
    see that bucket? your coolant is going in there.
  9. Mike@TTR
    Mike@TTR Active Member
    Damn coolant gnomes strike again!
  10. lostinthewoods
    I treated my vehicle for gnomes last week, so its not them.
  11. Mike@TTR
    Well, if it is not the gnomes, then it must be something else. We can pressure test it for you if you want. Just give me a call!
  12. wagunz_pwn
    he's in texas.
  13. Mike@TTR
    Haha, what's a little drive to get good quality work! Note to self....poopy diaper land is located in Texas.
