Coolant question
Discussion in 'Modifications & DIY how-to' started by shaolin, Jun 11, 2008.
  1. shaolin
    shaolin Member
    So of course my manual says only use genuine Subaru coolant in my car. The problem is that there are no dealerships near my house and with the weather like it is it will take a full day and night to cool down enough to change it. Can I just pick up some blue stuff at autozone or will my car subsiquently burst into flames?:eek3: Thanks
    just about any coolant is fine.....I'd get the pre-mixed stuff just cuz it's easier
  3. bomjoon
    bomjoon Active Member
    didnt you guys out them subaru juice. (blue thingy) into the mixture?
    i think that act likethe watter wetter but i personally dont think you need it. just goto the NAPA or Advanced auto and get you sum coolant.
  4. shaolin
    shaolin Member
    WTF?
  5. nicad
    subaru recommends their water wetter stuff for all cars now. maybe Will can chime in here. I've read it's pretty close to some of the off the shelf rad fix it products, but I dunno.
    someone also called Peak and verified that their coolant is almost exactly the same as the OEM coolant
  6. crashtke
    But the extended stuff is not recommended for our cars correct? Just pure ethylene glycol right?
  7. nicad
    according the manual scans I've seen, the extended stuff was updated to include all models. I was reading the NAZIOC thread about it yesterday since I'll be replacing mine this weekend.
    the thread is in the service&maintenance section
  8. SUBY_RUE
    SUBY_RUE Member
    Use PB, Iheard it works well...?
  9. kingwrex
    kingwrex Supporting Member
    you should really use only subaru coolant. the aluminum radiators in subarus dont like other aftermarket coolants. and the blue bottle from subaru is a conditioner that helps to stop headgaskets and other external leaks from happening.
  10. WJM
    Yes. I cant count how many radiators I've seen that come apart and/or clog up with the aftermarket coolants.
  11. Ben@TTR
    Ben@TTR Member
    Hmmm...interesting. I believe I'll be flushing the bad juice from my radiator now :eek3:
  12. nicad
    ok, I'll bite then. what's different about the subaru coolant than ANYTHING else on the market?
    I'm convinced it's nothing. as with most everything automotive related, there's only like 5 companies that make the shit. I don't have a warranty anymore, so I'm not buying subaru's rhetoric when it comes to voodoo coolants and aluminum
  13. kingwrex
    ill try to find and post the bulliten for you
  14. WJM
    While I understand your position on the matter ENTIRELY, there are technicians that have been around long enough that can tell you from looking into the engine's coolant passages what kind of coolant has been used.
    The SUBARU coolant leaves the engine looking nearly as if new as long as all the air has been purged and is changed once a year.
    Anything else leaves white residue or other contaminants due to the coolant and AL reacting with each other and the AL corroding.
    Your iron block engines dont care whats in them as long as its not straight water for a long period of time.
    If king doesnt post the SOA info by tomorrow sometime, I'll post it up.
    Now engine oil is a completely different story...
    Pick anything you want.*
    Pour it in.**
    Change it every 3k.*
    Use SUBARU filter.
    PROFIT!***
    Notes:
    *Depending on application, driving habits, environment and other variables.
    **Fill engine to manufacture specifications.
    ***Profits may vary. Not all profits are the same. Some profits are negative if note * is not observed.
  15. nicad
    I've seen the bulletin where they demand everyone use their coolant, but it's devoid of any technical info.
    sure, I'm not doubting the empirical evidence or the words of the techs. I just want some more info from subaru about their magic fucking coolant :mad:
    most important, what can I substitute since there isn't a dealership on my side of town.
  16. WJM
    You could ask king pretty please bring you some home since I heard some rumor that he lives in that general area...;)
  17. XanRules
    XanRules Active Member
    oops.
  18. SUBY_RUE
    SUBY_RUE Member
    I agree, I would like to see some info on this. I have used aftermarket coolant (such as prestone 50/50) for years and have never had any problems. So I would like to read up more on this so I can make a change if need be.
  19. nicad
  20. pEd
    here's another link that t3h WJM posted about this (even before Peaty posted that).
  21. WJM
    Every dealer was shipped a case of it...whether they wanted it not. :rofl:
    So somewhere at his dealer, there are 6 gallons. You will need TWO since its already 50/50 pre-mixed.
  22. nicad
    it was mostly rhetorical
  23. 5spdfrk
    5spdfrk Active Member
    Funny this should come up, as I was just about to post a thread asking if you could use the new super coolant in older MY cars.
    Also, back when I couldn't get the subaru coolant, I got some from NAPA, that according to the guys on nastysocks is pretty much identical. It's Peak's Global Anitfreeze which comes in a gold jug.
  24. bomjoon
    just get you sum racing radiator and put you sum regular off the shelf coolant. :)
    you get better cooling sys.
    and dont have to buy the blue stuff from suabru. :)
    win win situation.
  25. shaolin
    shaolin Member
    Well, before coming back and reading the rest of the verdicts on this post I ended up putting PEAK in my car. It was just a top off, not a flush. I will let everyone know if my car explodes.
  26. nicad
    I changed mine today as well (was planning on it anyway)
    my OEM fluid still looked green (just darker of course). noticed no real corrosion products. this was after 5 years.
  27. Impreza_RSK
    Impreza_RSK Member
    get some purple Ice by Royal purple it is supposedly a Awsome additive for any cooling system it lowers the coolant temprature its supossed to be like r134a for the coolant system.
  28. nicad
  29. Ben@TTR
    Ben@TTR Member
    omfg! lol ^^^^
  30. Ben@TTR
    Ben@TTR Member
    i checked my radiator today after reading this thread and i found a grey and black powdery substance in my radiator. is this the corrosion substance that everyone is referring to? my motor/coolant has 13k on it w/ prestone 50/50
  31. Cool_____
    The blue Subaru coolant is freaking expensive but use it! Buddy of mine used Prestone antifreeze in his car and after about 13 months (he was getting ready to flush it for the new winter) he started overheating. The Prestone corroded his radiator and he had wierd looking crap floating in the system. Had to get a new radiator and spent an entire day flushing out his car.
