cruise control dead
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Aug 25, 2007.
  1. Mad Mallard
    Mad Mallard the mad mallard
    [help]cruise control dead
    anyone else have theirs die?
    I tried to use it today, and it doesn't work anymore. :(
    Dunno what else to do. The Cruise light in the cluster isn't coming on.
  2. Jake
    could be a fuse??
    i know there was a factory recal on cruise control for the '02 and i believe some of the '03's not 100%. this might be something you may want to call subaru on, just in case...
  3. Deke
    Deke Active Member
    Yeah, it was on 03s too. Don't know if it made it up to 04s though.
  4. I think for the recall there was a clip that was put on to keep the cable from coming off at the throttle body.Check fuses.Mine died after sog did the recall for my o6.blown fuse.
  5. Mad Mallard
    i would, but it started working with the lunch drive
    i'll check it tonight, but if its that intermittent, you think its the switch?
  6. Alex
    Maybe or a loose fuse?
