cruise fail
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Dec 13, 2008.
  1. Mad Mallard
    Mad Mallard the mad mallard
    cruise fail (help)
    wasn't sure where else to put this...
    The hammer switch behind the steering wheel that controls my cruise is going out. I have to work it over quite hard to get it to 'resume' or 'set'.
    is this hard to replace/repair?
  2. Mad Mallard
  3. WJM
    You have to remove the steering wheel most of the time.
    I think there's a way to just take the airbag out and 'cheat' a little to remove/replace it. I've never done just the switch before, but I know its easier to take the wheel off.
    IIRC the airbag takes a T30.
  4. Mad Mallard
    well, i have 2 kinds of pullers when i had to do the same thing for my old car, except it was the turnsignal assembly.
    and i had a book. :/
  5. WJM
    You dont need a puller. Just loosen the nut and leave the nut on the last threads, enough that the nut is fully threaded tho. Then pull on the wheel, rocking it side to side and it'll pop right off.
