Custom fabrication/machine shop?
Discussion in 'Modifications & DIY how-to' started by Slowsoul, Jan 24, 2009.
  1. Slowsoul
    Slowsoul Member
    I wasn't sure where to put this.
    I need some custom washers fabricated. Does anyone know a machine shop that could handle that?
  2. calmnothing
    Washers for?
  3. nicad
  4. Slowsoul
    Slowsoul Member
    Actually spacers, it is a long story.
    They will be used in between the front bushings on the lower control arms to fill a gap between the bushing and the crossmember...so they need to be strong. I am currently using a stack of washers, but I would feel safer with a solid piece of metal there.
    Here is a picture of the gap.
  5. Slowsoul
    Slowsoul Member
    yeah...I downloaded their gui last week.
    They only have limited thickness options, and I need a specific thickness.
  6. nicad
    well, they can machine anything you want. it doesn't have to be a preset washer. just start off with a rod with the correct diameter/thickness and mill a hole through it.
    they can make it, guaranteed. you didn't try hard enough :)
  7. wagunz_pwn
    Try calling:
    Gazaway Machine and Tool
    1025 Nine North Drive
    Unit N
    Alpharetta, 30004
    770-576-0011
    ask for Andy...he's a gunsmith and toolmaker.
  8. Slowsoul
    Slowsoul Member
    :eek:...you are right, I only spent about 3 mins in the tutorials. I just went through the video tutuorials, and a few seconds later I had my design ready!
    Emachine shop can do the job for the low low cost of $177.00...
    I know that custom fabrication is not cheap, but I had no idea. I was thinking more a long the lines of the $30.00 neighborhood, maybe $50.
  9. Slowsoul
    Slowsoul Member
    post deleted.
  10. nicad
    hrm that's weird. it also depends a LOT on which type of machining process you choose, and the material.
    that seems pretty steep. what process did you choose? I can ask a guy at work if he can make it for me if you give me the dimensions. we have a full machine shop at the brewery. I imagine you want stainless?
  11. wagunz_pwn
    did you call my guy?
  12. Slowsoul
    Slowsoul Member
    I tried it with Stainless Steel and 6061 Aluminum. SS was about $3 more expensive.
    The machine I chose was the CNC Mill.
    is he working on a saturday?
  13. wagunz_pwn
    usually does.
  14. blindfold
    blindfold Active Member
    let me know if you ever find a price, i might need a special washer made too
  15. Slowsoul
    Slowsoul Member
    Called, didn't answer, I left him a message.
  16. goixiz
    goixiz Active Member
    I can cut/mill/turn it for you ?how soon you need it ?
    pm me -
    i have the capability and the access
    you dont need no sw with me - just sketch on napkin and get it to me
  17. Slowsoul
    Slowsoul Member
    Perfect.
    Thanks.
  18. goixiz
    get me the sketch before lunch and ill have it done by lunch
  19. Mike@TTR
    Mike@TTR Active Member
    Wow, you still have not quoted me any of mine from last week and you are going to get his done by lunch? I feel disliked Ming.:wtc:
  20. goixiz
    if yours is round with one hole in the middle
    then you get it after dinner :naughty:
  21. Slowsoul
    Slowsoul Member
    Thanks again Ming, the spacers worked out perfectly.
