Custom painted GR tail lights 08 STi
Discussion in 'Modifications & DIY how-to' started by FACE, Apr 6, 2009.
  1. FACE
    So while searching for exhaust I noticed these tail lights......Please click Photos for larger picture.
    I decided I had to have them.
    I had No luck when searching for some aftermarket tails but did see several people tinting or painting them... Clicky here if you would like to read more >>> GR Painted tails
    The paint choices people went with were; Testors Red; Duplicolor anodized red; and some tried stain glass paint. I think it really depends on what your going for. Some like the more opaque look (IMO how the Testors paint turns out) and some liked the clear red look (IMO like the Duplicolor paint turns out). Some folks like the much darker look I.E.
    These were done with the Testors. [​IMG]
    My choice of paint
    I started by removing the trim inside the hatch. You want to start by removing the trim at the top of the window, then the pillar trim and last the main cover. These are all pop on/off so be careful not to brake the clips. Next you will need to remove the bulbs and then using an 8MM socket and Phillips Head to remove the screws and nuts holding the lights.
    The corner lamps have 2 Screws (with socket heads as well) on the inside and a clip on the outside.
    The hatch lights have 2 nuts on the outer side and one nut you remove from inside the hatch through a small access hole.
    After removal I cleaned them with Isopropyl Alcohol and a clean micro fiber towel.
    Next I used masking tape to cover the turn signal and reverse lights....then onto painting.
    I did NOT sand prior to painting because I was worried that it would make them hazy looking instead of clear. The first 2 coats I did a VERY light mist with just enough passed to cover the light and WAITED 20 min. between the first 2 coats. I then did 3 more coats that were thicker and WAITED 1 hr. between these coats as well as giving them a little heat.
    [​IMG] [​IMG]
    Once they had dried awhile I removed the tape to start the clear coat. [​IMG]
    After 4 coats of clear and drying the install began. [​IMG]
    Big Thanks to 420 for Helping out and for giving a brutally honest opinion!
    I love how they turned out and can't believe I never thought of this with my 06!
    [​IMG][​IMG]
  2. FTZ
    So hot. This is the way the taillights should have came off the factory lot.
    We also painted the third brake light that is mounted to the rear hatch spoiler. We cut the wires and then crimped back together. We couldn't find any plug to undo, and it was only 2 wires, so we did the quick and easy route. It really tied in the look not having that clear light.
  3. FACE
    Badge removal and third brake light was takin care of by 420 :bowdown:
    :wiggle:
  4. Sparta
    Very nice man!
  5. Jake
    MUCH BETTER! i like that a lot
  6. integroid
    Looks 100X better!
  7. Trey
    Trey Active Member
    Ever since day one I've though the testors red was the way to go on the 08's. Very well done!
  8. Matt
    looks good homie!!
  9. oneiguy
    oneiguy Active Member
    SEXY!!! Way to go..
  10. wagunz_pwn
    until I see it up close, awesome job...now thank my useful post.
  11. wagunz_pwn
    before pic added for reference.
  12. pankopp
    pankopp Member
    much better, it looks great!
  13. FACE
    Thanks Cohen I forgot to add one to the first thread...no need to fix it now! :wiggle:
  14. wagunz_pwn
    I have seen it. Other than the -_ it does look damn good.
  15. josh booth
    josh booth Active Member
    Looks much better. :bigthumb:
  16. flat4ever666
    flat4ever666 Member
    killer! nice work
  17. Sparta
    what is the -_?
  18. wagunz_pwn
    when you see them in person...you will understand.
  19. Sparta
    Alex you need to call me for projects like this
  20. Dragan
    Dragan New Member
    I wish Subaru thought of this change... sharp looking and neatly done.
  21. Alex
    I assume you are referring to the driver's side tail light? :)
    Looks cool, glad you found the DIY I was suggesting.
  22. FACE
    Alex I appreciate your advice more than you know! I spent quite awhile reading through and deciding how I wanted to take it on!
    The _- that Cohen is referring to is where the corner light and the hatch come together. On the driver side the top lines are slightly off but the bottom is perfect.... the _- .........
    I am surprised that he (and I'm calling myself out here) did not notice the other pass. side the top is perfect but the bottom us off ;)
  23. integroid
    Face, was that you I saw on I75N today around 4:30?
  24. FACE
    yes sir! how could you tell? the tail lights?
    :wavey:
  25. integroid
    LOL...yeah, the tail lights and the half ghey wave you gave me:)
  26. ohmypearls
    ohmypearls Banned
    thank god; it looks so much better dude nice job!
  27. bixs
    bixs Supporting Member
  28. Matt
    it came clear....5 years too late. no one wants that shit anymore.
  29. longfury
    longfury Active Member
    I am too lame, lazy and cowardly to do this to my car. I would love to have red tails. You have no idea how bad clear tails look on a silver car.
  30. bixs
    you just don't realize how bad they look on these until you see pictures of them with red tails.
    and no i'd definately not want clear lol. i've had more than a few cars, admired many cars, and never thought to myself "that would look sweet with clear taillights"
  31. longfury
    I was hoping Subaru would give us factory red tails in the 2011 refresh. They didn't.
