How bad was it to wire it up? I'm guessing the ventilation channel is sealed off somehow, where'd you run the wire through?
I drilled a small hole in the vent duct and ran the wire and the hose out of their. Mike ran the wire to the dash clock so when I cut my headlights on presto gauge lights up. All in all it was a simple install and look very clean in the car. Its hard to tell in the picture but if you look at your air vent ther is a perfact 52mm circle if you cut a few things. And by the way you have to take the vent out of the car to modify(just pull like hell right kris).
