Cutting 2007 STi Fenders
Discussion in 'Modifications & DIY how-to' started by 07Ltd#767, Feb 24, 2010.
  1. 07Ltd#767
    Been searching and reading up on this for a few days now and this site is by far the best I've come across.
    http://t3hclap.com/archives/49
    Some of you may have already seen this, but I searched on here, IWSTI and Nabisco and it was surprising difficult to find any 'How To's' for this subject. I'll be documenting mine as I go so I can post up a little later on how things turn out.
    FWIW, I'm attempting to fit 265/35/18 tires on 18x9 +40 offset wheels on stock suspension (29/27 sways). I plan on using camber plates on the front and lower control arms on the rear to get -2.5/-1.8 camber after alignment.
  2. Alex
    Drew (t3h_clap)'s writeup is great. You can always send him a PM on IW if you run into any issues.
  3. WRX-WRC
    Im running almost exactly the same setup as you down to tire size. only difference is im running 18x8.5 08 sti wheels. I only ever get light rubbing at full lock in one direction with more towards posative camber than you.
  4. Alex
    What's the offset on the stock wheels though?
  5. 07Ltd#767
    i believe it's +57, iirc
  6. 07Ltd#767
    and how did you get that to fit on an 8.5" rim? these tires are already a good 2" wider than my 9" wheels
    *edit*
    I'm running 265 neovas, which are comparable to 275/285s in other brands...they run much wider than advertised for some reason
  7. crash#2
    crash#2 Member
    his car sits retardedly high for an sti...
    ...retardedly high.
  8. Meredith
    Meredith Banned
    I used to fit 275 wide V710s on the 8 inch stock 05 STi rim...
